Prosoft module in Redundant CLX system?
ckchew666
Aug 2003
Malaysia
591
Does anyone know if we can put a Prosoft Modbus module in the ControlLogix redundant CPU Chassis each? Will it cause any negative effect to the system?
Thx.
Look at the redundancy manual: it clearly stated what modules can be put in redundancy racks. Prosoft module is not on the list.
But you can put it in remote (I/O) chasis.
Thx a lot.
Hi all, I have an application where there is a Control Logix PLC connecting to a B&R remote I/O station over Modbus TCP via a prosoft MNETC...
1,929
I've worked on a handful of projects that relied on a Prosoft module for Modbus comms with other systems (older PLCs, boilers, chillers, much...
2,191
I am trying to set up a Dev address in a ProSoft MCM module. This module is acting as the master. The Modbus of the slave address is 7566 in a...
1,275
I'm running into an error I haven't seen before with regards to adding a Prosoft 1756-MVI56E-MCM card into a rack of an offline project. When I...
2,467
I have AB PLC 05/30 redundancy system,the system has actuator gate which communicating using prosoft module(cat no. 3100MCM) now on prosoft...
1,450
