Prosoft MVI69-MCM Config Port
Josh98
Mar 2024
NSW
Hi everyone,
I’m trying to copy the configuration from one MVI69-MCM to another.
I am having no luck establishing serial comms with the device via the config port.
Cables are as follows, RJ45 to DB9 adaptor – DB9 to DB9 null modem cable (I have made an exact copy of the wiring of prosoft cable no.15) – DB9 to usb ( serial to USB converter cable).
I have tried multiple different usb to serial cables with no success.
I have also read on some prosoft support pages that the baud rate for this port is 57600, setting the comm port to this doesn’t seem to help either.
I am using the prosoft configuration builder to try and upload from the unit, but I get “port opened successful” and then a timeout.
Can anyone advise:
  • What mode the processor needs to be in?
  • Any serial settings that may help?
  • If the cable configuration is correct?
  • Is there anyway to configure these modules via the backplane with CIP connect or other methods?
  • Does the processor need to have the MVI69-MCM AOI for the configuration port to function?
  • Do I need a right end cap terminator installed to use the config port?
I'm very new to this job, any guidance you can give me will be greatly appreciated.
Dear colleagues, could you help please. I have Prosoft Modbus module MVI69-MCM for CompactLogix PLC. With this module I need to communicate with...
648
Dear all, I am desperate for some help with a Prosoft DVI69-MCM MODBUS module. Details: Prosoft DVI69-MCM MODBUS module set up as slave with a...
5,715
Im having a bit of trouble trying to figure this out any assistance is greatly appreciated... Im using a Rockwell L32E compact logix controller...
2,336
Hi, I'm trying to integrate an MVI69-MCM module into my project. I need to be a Modbus slave and I need to send and receive data. I'm really...
6,253
Hello All, Quick question regarding polling a Modbus device (NuFlo Scanner 2000 flow meter) with a AB CompactLogix and a Prosoft MVI69-MCM card...
6,728
