Protection of a motor
The one closest the source in this case 1
Not because of the heat but it will see the inrush current first. Heat takes time to build up
Current in a circuit is equal at all points. One electron in one side, one out the other end (at only slightly lower than the speed of light).
Circuit beakers operate a lot slower than that.
Hi PLCs.net! I'm working on a multi-motor system, most motors are single phase, driven by servo drives. I wanted to check what kind of motor...
1,537
Any panel I've built with contactors and overloads has been 3 phase. I'm now quoting on one with some small single-phase loads. Definition of...
24
5,682
Hello experts, can you suggest me what would be appropriate motor protection switch for the following motor (used on a valve drive): 3 phase...
2,006
Hi all, Not sure how to call this, but my client wants a module that offers a dry contact, if one of three pump/motor bearing temperatures...
2,994
Hi guys, We recently had a rotary air lock jam up and it damaged the reducer, reducer base and keyway. It was a 3HP motor, 460V, 4.2A FLA, SF...
18
4,292
