Protocol creation in Omron CJ
Omronfaq
Oct 2003
We have an application whereby we receive approx 6k of ascii data from a serial device. We have created a protocol within CX Protocol and this works fine when receiving at 9600. We have no address, header or CRC defined, thus only raw ascii is received.
We seem to have problems receiving at 19200. Keep getting a "Framing Error" bit within PLC from SCU21 module. Any suggestions??
Data is being transmitted from a PC running hyperterminal (for testing purposes)
Also, any protocol examples with variable recieve lengths would be good to compare. We dont seem to be able to get ours to work correctly. We need exact data length otherwise protocol step is ignored.
Longwinded but hope someone can help.
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
348
I’m working on getting a Parallel Redundancy Protocol PRP system set up in a lab situation. The L73 PLC is in rack 4. 3 io racks are 1,2,3. I...
764
Does anyone have information or documentation regarding the protocol used in Rockwell's Remote IO, and how the physical layer of the network...
938
Hi everyone, I've got to interface 4 x Mitsubishi Q series PLC's with an Allen Bradley Compact Logix PLC using a Red Lion Data Station DSPLE000...
509
Dear Experts , I have a system which contains 10 PLCs (1214C CPU) each PLC with GSM module (Teltonika RUT955) and 2 SCADA PCs at different...
828
