Protocol ethernet/ip for elektronikon combox-e
Jul 2010
La Palma del Condado
Hello,
I'm working on an automation project, I'm trying to get data from an Atlas Copco compressor through a combox-e card, and the truth that the manual leaves much to be desired, and wondering if anyone knows the plots to be used or work.
greetings
I'll be as detailed as I can.
I did a project with the ComBox-E and spent several weeks analyzing its performance and conformance with the ODVA EtherNet/IP Specification. I chose to not use the ComBox-E and instead to use the ComBox-S and its Modbus RTU Proxy function connected via RS485.
The ComBox-S is popular, stable, and easy to use. I strongly recommend it. I have had excellent documentation, performance and support with the ComBox-S.
I read these post and download the tool from Atlas Copco, the program connects me to the compressor, but when I send a plot the compressor does not respond, how to not think I can be?
thank you very much for your attention
combox-E
What analogue value u are trying to read,Atlas Copco do supply a software to read the compressor values on screen.
Hi. Do these Atlas gateway need to be configurated by Atlas people? I got a MK5 gateway and do not know how to deal with it.
Hello, I noticed that SMP 4260 gateway doesn't list Ethernet/IP protocol as one of the available communications protocols. Does anyone know why...
1,185
I'm just starting trouble shooting a production Line that shuts down due to Ethernet faults. The line has been disconnected from the rest of the...
3,512
Hi all, I was wondering what the protocol is for Ethernet to reestablish interrupted communication and how long this takes. Maybe this info...
1,654
We've had this working over RS232 for several years using AWT and ARD ASCII commands in the Controllogix program. Markem has now unleashed an...
11,235
Hi, I have seen some industrial devices that mention Ethernet UDP as a means of communication.. I know they use ethernet communication but is...
2,852
