Protool Runtime Problem
Oct 2007
Alberta
Can anyone help with with an issue I have been having for about 6 months? I have protool runtime running on a sinumerik 840di machine operating a threader but every so often the runtime will lock up and show only #### signs. We have had the machine rebuilt, re-installed all software from scratch and even bought a new hard drive for the 840di. We have also checked all profibus connectors and cables but still we have the same problem. Does anyone have any ideas or know the cause and solution to this?
When there is a comms problem for example, there appears a system message with an error code. The error code will tell pretty precisely what is wrong - in most cases.
If the message disappears before you get the chance to see it, then go to a message view that displays all system messages. If you dont have such a message view, then add such a message view to the project.
Hi all, I am using Protool 6.0 with Step 7 V5.3 and Simatic S7 300. The problem is that in Runtime mode when I push switch button to ON position...
2,705
I am attempting to inmplement a runtime meter in one of our Siemens PLCs. I am using SFC3 to start/stop the runtime meter, and SFC4 to read the...
3,654
Hi everyone, I am new to this forum and this is my first post. Unfortunately it's a NEED HELP post. I'll appreciate any help. The problem is that...
5,270
I am posting for the first time. I have problem starting the Protool Loader. Whenever I start the Protool Pro RT Loader the following error...
2,482
Hello, I have the following configuration: Siemens PanelPC 577 CP5611 WinLC V4.0 Protool Runtime ET200S So far all the...
4,939
