ProWORX NxT Activation
aiki202
Aug 2007
Pennsylvania
178
I am trying to activate ProWORX NxT on a Win 7 OS (I know it is not supposed to work but this is not my issue). When I activate it under my log in it opens fine but no one else that logs in to the same PC has the activation (only my profile). Anyone know how to activate the software to allow All Users access? I know it can be done as we have other PCs with this capability.
I am a long time AB person...new to Modicon & ProWORX.
Thanks in advance!
aiki202, Did you have any luck finding the problem? We're having the same issue. Just moved to a Windows 7 box using the move procedure they outlined in their instructions. The first user registered has access, but no one else. Support hasn't responded to any tickets...
Thanks!
The work around is to have each person log in (each profile) and activate the software from the local license key file. As you may already know ProWORX NxT support ended a long time ago.
Also, for us it is hit or miss with using Win7 and Ethernet connectivity to go online with PLCs. My laptop seems to work most of the time while others always have issues. We all keep our PCs up to date with MS updates...same anti-virus software...but something is apparently different between the same physical model laptops. Just though I would mention it. We have not found a solution to this.
We are looking at upgrading to Unity or moving to Rockwell.
Hope this helps.
Thanks aiki202 for the information. We were migrating from another installation and the site ID appears to be different for each user. The migration utility migrates from one site id to another site id... Because the site id appears to be different for each user, the license file get's denied. We're still attempting contact with support.. sigh. Your information is very helpful and we appreciate your sharing.
Thanks!
We had the same problem and even had it with Proworx32 (a true piece of garbage software). We eventually changed to PLC Workshop for Modicon, but that is an expensive option.
Check your private messages.
I have a zip file of a program that I'm told was created in Proworx NxT. Would the comments be stored in it if I could find the software or...
573
Would like to ask .. if anyone here know about creating own library or function block on ProWORX NxT ? I have a backup of ProWORX NxT project...
1,060
Hi to all. Somebody knows how activate or authorize ProWorx NXT. I was searching in other forums and I don't find info about this. I already...
1,252
Hello, I was just wondering if someone could help me by converting a .pwx file to .nxt. I am trying to open some code for a client but only...
1,503
I'm trying to get ProWorx NxT running on VMWare on a Win10 host. I've tried XP and NT Workstation 4.0 as the guest operating systems. When I got...
2,942
