Proworx NxT
stevegodber
Mar 2004
Modicon PLC 984-685E
Anybody know how to use ADD or ADD16 to put the HEX value 7FFF into a register ( 4xxxx ). I can't enter values in HEX and seem to be limited to decimal 9999.
What I really trying to do is use ladder to ensure a certain register always gets loaded with this constant value through ladder.
Problem I had was the value got loast when the PLC was powered down and then it messed up a whole train of calculations. Hence I don't just want to write a number into the register using the register editor.
To be compatible with legacy ("old BCD keypads") equipment the default maximum value for registers is 9999 decimal. You can change this in ProWorx NxT by going to File-Preferences and checking the option for 65535 as the maximum value. However, through a quirk in the ProWorx software you can still only enter 4 digits (9999) in the math functions. The old Modsoft softae does not have this quirk.
If I wanted to hard program a preset value of 7FFF into 40001, I would use the MU16 function and decimal values. Note: In really old versions of the 685E executive the result might actually be in the implied register (40002). Normally, I would use the Register Editor Window and enter my value directly in Hex, then I would Save and Load STATE RAM values along with my ladder logic.
---|#4681|
| 7 |
| MU16|
---|40001|
Jim
Thanks for your help.
Iyou had replied to another matter regarding the DRUM loadable.
I managed to get a .dat file from a local Modicon source.
(just incase you ever need it)
Regards
Steve
I have a zip file of a program that I'm told was created in Proworx NxT. Would the comments be stored in it if I could find the software or...
581
Would like to ask .. if anyone here know about creating own library or function block on ProWORX NxT ? I have a backup of ProWORX NxT project...
1,066
Hi to all. Somebody knows how activate or authorize ProWorx NXT. I was searching in other forums and I don't find info about this. I already...
1,261
Hello, I was just wondering if someone could help me by converting a .pwx file to .nxt. I am trying to open some code for a client but only...
1,520
I'm trying to get ProWorx NxT running on VMWare on a Win10 host. I've tried XP and NT Workstation 4.0 as the guest operating systems. When I got...
2,946
