ProworxNXT & Momentum 760-10
anks
Dec 2004
California
66
Using proworxNXT & momentum combination and trying to latch my coil bit (set/rst), but only coil options i have are of regular coil and the coil with a word 'L' on it (latch coil), how can i unlatch that coil bit ...basically need to set/rst my coil?
I dont have NOBT, NCBT option either.
You are actually programming using the Modicon 984LL instruction set, ProWORX NXT is just a software package.
984LL does not have true Latch/Unlatch (Set/Reset) coils.
The "L" coil will remember if it was "on" when a power down occurs (the program stops scanning). On the first, scan after power up the L coil will "automatically" energize for one scan. After that it will go back to acting like a regular coil. In the old days this L coil was used like the "start" contact in a three wire control where the "U" function was the "stop" contact.
1x1 0x100
---] [-------(L)----
1x2 0x80
0x80 0x100 0x11
| 0x11 |
Can anyone email me the PID loop example using proworx nxt software for Momentum PLC. The thing is my analogs are from 0-32,767 & PID loop only...
2,124
In the Proworx NxT help file there is a reference to a function block titled "1X3X". The purpose of this block it to allow values to be...
5,419
Hi, Is there any difference between ProworxNXT and Proworx32? or they are the same software. I am planning on using that for my Momentum PLC...
2,214
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
100
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
89
