Proximity sensor programming
jmhett
Oct 2003
Tyler,Texas
I need help to program in RS Logix. I am reading inputs thru IB32 to
count the shaft revelutios. I am using 2 proximity sensors per shaft,
As long as the program sees 2 counts in a time period operation is ok,
if only one count in the same time period will indicate a sensor failure, if zero counts in the same time period will indicate a shaft turning failure. I am trying to use a CTU counter & a EQU counter in my program, but not quite sure how
Are you just trying to verify the motion of the shaft?
If you need the 2nd prox, set this up twice, and if one says your running while the other says you aren't, you have a sensor failure.
Hi Members, Currently, I'm working with Motor Generator speed measurement. Just wondering if possible or not my integration system for speed...
1,978
Newbie here - I'm working on a project for a class and experiencing problems with getting my proximity sensor to activate a solenoid. I'm using...
3,375
Does anyone have a suggestion for some kind of proximity sensor that would detect if an object is sticking out of a cup? A stationary cup, so it...
3,265
Hi everyone, I have a simple question regarding proximity sensors. How many types are there exactly? From my understanding there are inductive...
2,392
