Pruduced and Consumed Tags In An Array
Richjr
May 2013
West Covina, California
I was unable to find an answer while searching, so I decided to start a new thread.
I'm in the process of creating produced and consumed tags over Ethernet to start a process from a Control Logix processor (producer) to a Compact Logix processor (consumer). My question is regarding creating produced/consumed tags using a DINT array. On the consumer side, what would I put in the "remote data" for the tag name, Purge_HMI_PB or Purge_HMI_PB[16]?
Thank you in advance for any help, it is greatly appreciated.
Let's take a step back and look at the whole picture, I think that'll help you understand the best...
Let me assume for a moment that your DINT array has 100 elements. So your Produced Tag in the ControlLogix is Purge_HMI_PB, which is of the data type DINT[100]. Purge_HMI_PB[16] is just one element of that array, that is to say, one element of your Produced Tag.
Your consumed tag, in the CompactLogix is called, say Remote_Data, and must be the same data type as the produced tag. So Remote_Data must also have the data type DINT[100].
From here, you can probably see where I'm going with this. Your produced tag in the ControlLogix is Purge_HMI_PB, so the "Remote Data" in your consumed tag setup must be Purge_HMI_PB. Purge_HMI_PB[16] is again, just one element of your produced tag, and it will be copied to your consumed tag in the same position (i.e. Remote_Data[16]).
Make sense?
That definitely helped me understand it much better. I am still in the early stages of programming and loving it, but I definitely need guidance. I really appreciate you taking the time to explain it, rather than just giving me the answer.
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
189
Hi I have been knocking my head against the wall trying to figure out why these two plcs won't talk with Produced and Consumed Tags data. The...
493
Hello all. I have a 1769-L16 that I inserted a 1769-L35E into. I was expecting it to create module defined tags automatically in my controller...
1,824
Hi, Can a tag configured as a Produced or Consumed tag be read or written to with Explicit Messaging? Context: we are retrofitting an AV system...
2,287
Ok, I've setup comms to PLC's that are behind a NAT switch before, but I have not had a PLC behind one NAT switch communicate with a second PLC...
3,457
