PTC wiring in encoder cable
Plc_User
Dec 2005
Belgium
317
We want to use spare wires in the encoder cable to wire also the ptc of the motor. Only thing I am worried about is the voltage drop on the wires. The standard cable we use have wires of 0.35 mm2 or 22AWG and the cables have a maximum length of 50m or 160 feet. Will this cause trouble?
We want to use spare wires in the encoder cable to wire also the ptc of the motor. Only thing I am worried about is the voltage drop on the wires. The standard cable we use have wires of 0.35 mm2 or 22AWG and the cables have a maximum length of 50m or 160 feet. Will this cause trouble? Thanks
Uhhhh what is ptc in a motor?
Dan Bentler
A PTC is a motor thermistor and if you see how they are placed in a motor winding you would think twice before you ran the wire from a PTC thermistor in with most other wiring.
If wires chafe, or motor burns out, there is a remote possibility of a supply voltage being introduced into that cable, which would have no real effect on the thermistor, but could affect other items such as your case encoders.
I am with Gil47 on this one. The risk of getting mains voltage on the low voltage circuit far outweighs the benefit. Run the extra cable!!!!
Bryan
Hi, Have anyone came across issue with Kepware or Linkmaster not returning correct values (Unknown Quality) for some tags From OPC DA Client...
684
Can someone explain how a Powerflex 525 drive interprets the PTC Thermistor signal from a motor winding? How does one know what the levels are or...
4,037
Hello all, I am using a Sinamics G120 CP 240E-2 PN-F control unit to drive a Siemens 1LE10030DA222AB4 3-phase 1hp (0.75kW) motor. The motor has a...
5,104
Hello eveery one, I want to know weather PTC cable from motor to MCC can be clubbed along with 110AC control cables or need a seperate cables ...
1,510
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
134
