Pulse Generation for Stepper
lape_a
Guest
L
Can any body advie me on how to generate a 2Hz pulse on the PLC CQM1H CPU 21 of Omron? Thanx a lot..
Pulse generator
BobB, you mean an Omron PLC ryt? Its a PWM and INI instruction that must be use to generate pulse. Can you please give an example ladder for that, please. For an 1.5Khz pulse.. thanx a lot..
I have not used it but the instruction help shows that if F is set to 001, the frequency is then set at 1.5kHz. D is set for duty cycle. I can help you no further than that. Also, note that only 2 outputs can be used for the function.
hi guys. Can any one give ma an idea on how to generate 20KHz pulse, using CQM1H PLC of Omron? Also by using S500 PLC of Allen Bradley? Thx....
2,928
Hello I want to generate a continous Pulse Train Output at a certain frequency using Y0 output of Fatek FBS-20 MCT PLC for a Stepper Motor...
1,902
I have a new OMRON PLC CP1E-N400DT-D, the problem is I can't generate pulse output with command SPED/PLS2, every step base on Omron instruction...
9,456
Hi everybody Now, I having a project in there I will use Pulse Generation with FB43"PULSEGEN".So Does anybody know about it, and you have user's...
3,900
Hi, I just want to use a timer to make a pulse that lasts one scan (cycle) every, say, 1 second. That is, I want for example M0.0 to be '0' for...
37,959
