Pulse Generation using Fatek FBS-20 MCT PLC
Jul 2017
Dubai
Hello
I want to generate a continous Pulse Train Output at a certain frequency using Y0 output of Fatek FBS-20 MCT PLC for a Stepper Motor Drive.
The Pulse Output can be continous as the Motion of Stepper Motor is cut by proximity switch.
Please advice if anybody knows to generate the same using HSPO or PLSO command in winproladder
Mishal
+971561885877
[email protected]
If I remember correctly, the fatek is a clone of the mitsubish fx series. You may have more luck looking up mitsubishi documentation for help.
Hi, I just want to use a timer to make a pulse that lasts one scan (cycle) every, say, 1 second. That is, I want for example M0.0 to be '0' for...
37,962
I have a new OMRON PLC CP1E-N400DT-D, the problem is I can't generate pulse output with command SPED/PLS2, every step base on Omron instruction...
9,456
Hi everybody Now, I having a project in there I will use Pulse Generation with FB43"PULSEGEN".So Does anybody know about it, and you have user's...
3,904
hi guys. Can any one give ma an idea on how to generate 20KHz pulse, using CQM1H PLC of Omron? Also by using S500 PLC of Allen Bradley? Thx....
2,928
L
Can any body advie me on how to generate a 2Hz pulse on the PLC CQM1H CPU 21 of Omron? Thanx a lot..
2,578
