Put/Get using S7 Connection Status
boneless
Feb 2008
OKC
1,628
Hi all!
Trying to figure out if it is possible to monitor connection status in my program (like device status). We generally use our own watchdog, but was wondering if there is a standard.
Thanks!
You can look NDR, done and error outputs and make communication counters.
one of these bits are true for one PLC scan after message is maded.
Hi, yes we could do that, but was hoping for a system function(block).
Yeah we do something similar, it is pretty simple. But my co-worker was sure he had seen a standard block at a seminar.
PUT and GET should always carry a heartbeat or rolling counter as the instruction functions even when the partner PLC is in stop. It's not the end of the world not having one, but it's good practice.
I have a robot cell controlled via PLC. I want to use an output from the PLC, based on whatever part number the cell is processing, to open a...
911
The cards have two internal 3.15A fuses, one for each group, and a 0.5A max current loading per point @ 60°C (140°F). They also have a 5A surge...
1,079
Hello. Is there a way to bind keyboard keys on the computer running the simulation of the PLC so that you can emulate button press etc during...
736
Hi, Is there an easy way to limit the input tag by using min and max tags from the PLC? Thanks
1,286
So I am new to the plc scene, and I am working on a machine that gets a fault, to which I think it is a overtorque fault. I did some research on...
1,986
