PV 300 "Hearbeat" Monitor
maverick33
Dec 2005
USA
36
Does anyone have any ideas on how to set up a "hearbeat" monitor for a PV300.
Here is what I have:
Contrologix processor communicating over serial link to PV300.
PV300 acts as a "remote" to control some things from up to 20 ft away.
What I want to do:
I want to monitor the status of the communication link from the processor to the PV300 and stop certain functions if the PV300 and the processor lose communication.
What I have tried:
I tried using the "message to remote" function in panel builder 32 but have some problems with it. I am using the notification tag and handshake tag to basically toggle a bit on and off via the PLC and processor. This sometime works and sometimes not, meaning that if it is up and running and I pull the cable out the notification bit stays on and is never cleared since the handshake from the PLC is never received. Also, when I cannot get this functionality to resume if I pull the comm cable and then later plug it back in. As far as I can tell PV300 doesn't support macros and the only way to set a bit is by actually pressing a button on the PV300... did I miss something?
Anyone have any ideas on another way to accomplish this?
Thanks in advance...
An entirely different approach might be to GSV the channel 0 comms status in the PLC. I have never done this but I'm sure there's something available. (In a SLC or Micro, i just use the Ch0 Comms Active bit for stuff like that.)
Paul C
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
93
119
279
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
65
79
