PV 600 2711-K6C5L1, DH-485 Com Cable
bright676
Nov 2012
va
494
Is the communication cable for this PanelView a straight through 9 pin cable? It uses DH-485.
The manual doesn't say if it is or not.
Thanks a bunch.
Yes, the cable from the PanelView's DH-485 (RS-232) port to a PLC or a PC should be a "straight through" cable.
PanelView Standard terminals have a "DCE" type port, so you connect them straight through to any device with a "DTE" type port, which includes SLC-5/0x controllers, MicroLogix controllers, ControlLogix and CompactLogix controllers, and PC serial ports.
2711-k6c5l1 PanelView 600 to Ethernet I have a old PanelView standard 600 I plan on using in my garage for setting up security. The garage is...
1,868
Hello, Friends Please someone help me find right cable to communicate Panelview 600 (2711-B6C9) to Micrologix 1200 (1762-L24AWAR). AND any advice.
272
I'm a beginner to PLC and Hmi programming. any one please help how to connect HMI to pc. HMI has a printer **** enabled by default, It does not...
425
I have a used PV600 I plan to use to replace the one at my customer's that lost it's memory. There is a program in it, so I thought I'd practice...
1,313
hi all, i have 1 new panelview 600 need to download my backup program with panel builder 32, can someone please teach me how to establish the...
1,614
