PV+ Printers
lostcontrol
May 2009
NeverSayNever
1,071
Hello,
We have a PV1000+ that has an old HP1000 USB printer attached. This has been working fine for a year and a half, but now seems to be playing up. It was 2nd hand when we sourced it, as it was all that we could find that would support the PCL3 protocol.
I fear that I am going to find it even harder to source a compatible printer now, as back then, the current protocol was PCL6 I think.
What I want to ask is:
1. Is there the facility to update the PV+ firmware, to enable it so support modern printers, or is this but of the embedded CE OS and not possible
2. Anyone know where I can source a PCL3 printer that is supported by the PV+ range?
According to the HCL, models HP5651, HP5440, HP Deskjet 9800, HP6940 & HP6980 are 'certified', but trying to source these is not going to be that easy I do not think.
In theory, newer printers are 'backwards compatible' with PCL3, but I am pretty sure I tried this last time, and did not have any joy.
Interesting, so that device converts a Parallel port signal to a USB, and appropriate for the printer/protocol attached?
Looks good, but the printer I have at the moment, is attached to the PV+ via USB, I wonder if there is something similar that would do the same thing... time to google!
Have you used this device with a PV+?
I use them with PV+ 1000 CE units to print a paper copy and a pdf of each print action.
Ok, so next question(s).
1. As far as I can tell, the hardware is the same for the PV+ & PV+ CE, so what are the differences?
2. This device requires parallel port connection, but I cannot see that the PV+ has one, only the USB & Serial connections, how do you connect to the PV+?
3. Do you have a PC connected directly to this always, via the USB connection, and a printer connected to this PC?
4. What do they cost?
Update
I managed to find a printer of the ebay equivalend down here, and have tested with a Bench unit that I have, and was successful.
The model was a HP5550, but is also a superseded unit. From some of the reading that I did, I sort of established that most Deskjet printers support PCL3, whereas some of the others are PCL4 & 5.
I should maybe go to the local computer supplier, and try testing with a deskjet, and see if that works, will confirm a few things...
I did try contacting HP as well, to get some more detailed information, but have not heard back from them yet, if I do, I will post info back here.
I am currently working with a Zebra printer (ZT230) and a Controls Logic(1769-L30ERM PLC with RSLogix 5000 v20.05) PLC, and a PC with Windows 10...
2,133
Looking for feedback on the "Ethernet IP" factor of these printers and the interface with Controllogix PLC's. i.e. do we need an EWEB or EN2T or...
1,572
Hi, I am required to link up a Allen bradley micrologix PLC with a label printer to allow automated requests. Does anyone have any experience of...
4,276
I've been told I need to set up communications between a few Linx 7300 printers and our PLC over Ethernet. The printers were provided by our...
2,203
Good Afternoon , I am looking for Industrial Ink Jet Printers that mark cases of product with Bar Codes , Lot Numbers , etc. I'm looking to...
2,040
