Linx printers
treellama
Jan 2016
Delaware
39
I've been told I need to set up communications between a few Linx 7300 printers and our PLC over Ethernet. The printers were provided by our customer. Anybody do this before?
I found a document for their "RPC" protocol online, but it's not complete. For example, they don't list a port to use to connect a socket. I scanned for open ports and found only one, and I was able to connect a socket to it, but I don't get any response when I try to send a message. I've been working in visual studio for now, I figure if I can make that work then I can port it to TiaPortal
I'm hoping someone here has fought with these before and either has some more documentation than I could google, or at least tell me it's impossible.
The RCI-08 000 communication manual, literally the first google result, tells you the port is 29043 in chapter 1.4.2
The entire comms protocol is pretty straight forward. Better to start on it in TIA cuz the data handling is very different, you'll spend enough time figuring that part out even after you get it to work in VS.
Thanks Jeebs.
I swear I googled and googled and never found that particular version of the manual. 29043 is the correct port, it responds as expected now. I think I'll take your advice, as soon as I get the PLC in I'll do the rest of my testing in TiaPortal.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
195
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
107
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
231
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
158
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
105
