PV+ & RSLinx Enterprise Problem
Dave Steer
Nov 2002
Devon
27
Hi all
Hope some one can help me here. I am trying to set up commnunications between a SLC 5/03 using Ch0 DH485 Node 1 to a PV+ through its serial port. I have never used RSLinx Enterprise before and I'm struggling to understand what the Runtime shortcut should comprise of. If some one could give me a pointer to what drivers should be added and where they would appear in the tree. Or if anyone has any idea where on the very hard to find your way around knowledge database, I can find how it's setup for serial communications.
I am commnuicating with the PV through the Ethernet connection, but this is purely for programming the PV, this works fine by the way. I am also communicating with the SLC at the moment using another laptop with a PIC connected on the DH485 port.
Thanks in advance
Dave
Hi, It's seem like it's is easy to install RSlinx Enterprise, However i found some problems. I have : ---Windows 7 64bits ---Factory Talk...
1,713
I have problem about RSLinx Enterprise (FactoryTalk View SE) as follows; 1) I create Device Shortcut name (such as name "ABPLC") and match...
2,225
Hi all, I want to connect to a PanelView Compact 400 to download application. But in the transfer utility, I can just see a yellow question mark...
2,618
Hi, We are configuring a FTView Site edition in network mode with a FT Activation Server license. When we try to create a Data Server we obtain...
2,858
Hi all Hope some one can help me here. I am trying to set up commnunications between a SLC 5/03 using Ch0 DH485 Node 1 to a PV+ through its serial...
2,040
