PV550 - error 396 - filoe not suppôrted
MGuenette
Jan 2007
Montreal
134
hI, finally i have a problem with the PV550. I always get the error message 396 - file not supported. The user manual tells me to contact tech support.
Any suggestion before I contact tech support?
PV550
I have the right setting in panelbuilder without error when creating the PVA file.
thanks
Martin.
I'm not 100% sure about this but "file not supported" errors usually have to do with the firmware. In panelbuilder under "terminal setup" there's a "catalog & revisions" button, verify that it matches the firmware on the panelview.
Good luck
I have a 2711-K5A2 (PV550). When I power it up (with no connection other than power) I get error 24 (Performed CRC base firmware check). The...
2,341
Hi, I have a PV550 DH+ and a SLC 5/04. I just changed the 5/04 last sunday by another one and since the PV does not communicate with the SLC...
2,673
Dear friends, I have a problem with panelview 550, I have an error "Comms Error = 13" as I can correct this or in where I can to obtain...
2,363
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,229
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,678
