pv550 removal
carrot
Jun 2012
london
Hi
I have to modify an installation
SLC 5/03 connecting to 2 PV550 VIA 1761 NET UIC
One PV is connected by a Null Modem cable and 1 via DH485
The DH485 connected PV is the one being removed
When I remove the PV 550 , what changes in the RS LOGIX 500
software will I have to make so that the SLC does not look for the removed Panelview
Cheers Any help much obliged
:ROFLMAO:
Your SLC5/03 does not look for a panelview. Panelviews do the polling. So you don't have to do a thing.
Were the programs in each PV the same?
Hi Mickey
Ok Thanks so I just have to remove the cable connection going out to the PV and all is good ?
The programs in each PV are showing 2 different sequences of a SLC
program.I have removed all the relevant SLC software for the old sequence.
Thanks Bruce
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,229
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,682
We have an old machine that has been mothballed since early 2018 and management are looking at more work for it in 2022. The system runs on an SLC...
2,885
Trying to write a program for a PV550 (2711-T5A16L1, Ser. B, Rev. E, FRN 4.46) to test the touchscreen. I wrote a program with 16 pages and on...
1,696
Good Morning Folks. Win Xp, PRO, Version 2002, SP3 RSLinx Classic 2.54 Using the AB UIC-485 driver with the 1747-UIC and a 2711-NC13 connected...
1,223
