PV550 Stacking objects
alphav
Supporting Member
Sep 2007
Ontario
35
Hello,
I have 8 different numeric values shown on a PV550 in a row as "Numeric Values". From the PLC I want to control the HMI so I can indicate whitch "Numeric Indicator" is selected by showing a box around one of the "Numeric Indicators"
For each of the "Numeric Indicators" I have an "State Indicator" as an underlay. The Idea is to change the Object Foreground to black for the one there is selected, and to white for the other 7. (The "Numeric Indicator" is moved to the front).
The problem is that when I change the Object Foreground on the "State Indicator" the "Numeric Indicator" is not visible anymore.
Any suggestions how to solve that problem?
thanks,
gert
It's been a while but if I remember correctly in the list of the object setup states options there is an option that will change the numeric value from black to white or vise versa depending on the foreground state (you may have to change the background state). The option may be hidden in the list, you have to scroll right to see all the options. There are other ways to do it. I will open up panel builder and play with it.
Thanks for the reply,
I do not think that the object is hidden. After I change the state of the background object, and then change the numeric value of the foreground object, then I can se it. It is not enough just to rewrite the same number, I have to write a different number for the numeric object to be visible.
gert
Doesn't Panelbuilder give you a warning about overlapping objects when you do this? It's been a while since I worked on a standard Panelview, but I don't believe you *can* stack objects and have them work properly.
Try changing your "highlight" object to a rectangle above or below the numeric and see if it functions properly.
Not sure if this is what you are trying to do. Take a look.
Hi Kbpatton,
Sorry for the delay answering you. Yes that is excatly whan I want to do, but I have more than one set. The problem is that when I change the Object Foreground on the "State Indicator" the "Numeric Indicator" is not visible anymore.
gert
Hey, I guess I'm still not sure what you need. On that small app. I posted, if you cycle the state of the indicator behind the numeric indicator from white to black, the numeric indicator is still visible.
Thanks Kbpatton,
I made a small PLC program and added some addresses to the HMI program you forwarded. (see files) When I change the look for the Multi-State Indicator my text value still is not visible
gert
Wrong Files See next Post
Thanks Kbpatton,
gert
I took a quick look. First, don't forget the "Arrange" option. This is used to bring objects to the front or move them to the back. Second, your PLC program is using N7:3 and N7:4 for the indicators but those addressis are not used in your PV program.
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,228
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,671
We have an old machine that has been mothballed since early 2018 and management are looking at more work for it in 2022. The system runs on an SLC...
2,879
Trying to write a program for a PV550 (2711-T5A16L1, Ser. B, Rev. E, FRN 4.46) to test the touchscreen. I wrote a program with 16 pages and on...
1,695
Good Morning Folks. Win Xp, PRO, Version 2002, SP3 RSLinx Classic 2.54 Using the AB UIC-485 driver with the 1747-UIC and a 2711-NC13 connected...
1,222
