Pv550
LStewart
Apr 2005
Mississippi
95
I sure could use some help communicating with a PV550, I have a 2711-B5A9 with 2 RS232 ports one for printer and one for communication and download. I have tried talking to it using RSLinx and DF1-1 Driver with a a 1747-cp3 cable, I have tried using this with a null modem. I have tried using my pcm card and using a gender changer with my 1784-PCM cable. I have commicated with it in the past, (4 months ago), and remember having to change something to be able to talk to it using a RS232 cable, but looks like my old age is catching up and I can not remember what I did to talk to it. I do remember the last time took me forever to establish communication also. Any hints or suggestions?o_O
Think from memory that unit uses DH485 not DF1 with a RS232 connection.....Try using the PIC driver in Linx........
Hope this helps (y)
KidBlue is right. It is a DH-485 unit.
What I always do to figure out this is open up Panelbuilder 32 and create a new Project. On the screen where you are selecting the PV and its Protocol, It will be displaying the part numbers above the selection box that matches the protocol. I find this as an easy way to check or build part numbers, .... easier than finding the correct literature or manual anyways.
$#*! No go! I found my notes from when I talked to it last time and followed them. Still no joy. I am wondering if the PV has a problem. Thanks for your help anyway. Tomorrow is another day maybe my luck will improve.
To program a PV550 on RS232 you need an NC13 cable, this is a straight-through RS232 cable. If its DH485 on rs232 then use RS linx and the PIC driver. If its RS 232 DF-1 then use the DF1 driver. On the older panelviews I think the second rs232 port is printer only. The cp3 cable doesn't work with panelviews.
The main communication port for that model is DH+
Manual, check chapter 1 page 3: http://literature.rockwellautomation.com/idc/groups/literature/documents/um/2711-um014_-en-p.pdf
With DH+ you will need to use PCMK or some adapter.
The RS232 port can be used for file transfer but as stated you will need a straight thru cable like the 2711-NC13. From what I can see it should use the DF1 point to point driver.
Cable wiring:
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,229
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,685
We have an old machine that has been mothballed since early 2018 and management are looking at more work for it in 2022. The system runs on an SLC...
2,885
Trying to write a program for a PV550 (2711-T5A16L1, Ser. B, Rev. E, FRN 4.46) to test the touchscreen. I wrote a program with 16 pages and on...
1,696
Good Morning Folks. Win Xp, PRO, Version 2002, SP3 RSLinx Classic 2.54 Using the AB UIC-485 driver with the 1747-UIC and a 2711-NC13 connected...
1,223
