PV600 Help....
DanielCamacho
Mar 2005
Querétaro
208
I am adding a standard Control List Selector... Can someone tell me what I need to do to get this List selector to update when the PV is Initiated? With the "Standard" selected I can only set the Initial state. I have 7 values writing to one N7 word, the PLC has for example a value of 4 but when I download the PV app these List Controls do not diplay the correct value... The other option is the "Piloted" Control List Selector, but not sure how to use the "search tag", "Control tag" and the "Block write start" fields... just a simple answer, for a simple mind... :unsure:
This way the N7:0 will always have the correct value displayed?
Or Like this?
I dont quite understand your question / what you are trying to achieve
The control list selector Standard just writes a value to the PLC from the Op Interface to the Write Tag that you assign.
The List is Assigned a function key to activate it, then the operator chooses what he wants using the up / down arrows.
Let me explain...
Writing to the PLC is not a problem... I have a 7 item list, if the second item is selected I send a value of 2 to the integer file. The problem is, when the PV application is downloaded the screen containing the list selector always comes back at a default value, I would like it to come back with the actual data in the PLC... Instead of being on the first item in the list to be high lighted to the second position again if the integer is still a 2, or third position if 3 etc... This is just a visualization problem. I think the "Piloted" item list selector will correct this but it looks like to me, you have only two choices;
1. Set the data from the PanelView but not read, with the "Standard" item list selector
2. Set the data in the PLC and the PanelView will read the data, with the "Piloted" item list selector.
I want to do both, I think this is not possible...
Not sure...
RBEYER said:
Can you use the power up settings, which writes the last settings the PV had instead of using the default.
Not sure, don't think it is alowed, the properties page for the control list has an initial value list box, but no way to disable that...
PV Help said:
Initial State
Specifies the default state on initial power up of the terminal and the initial value sent to the write tag address. The initial state value overrides the initial value in the Tag Editor (if entered).
Allen-Bradley Company, LLC, Copyright © 1993-2002, All Rights Reserved
No replies...
Guess I am the only person to have this problem? Or not important for the screens of the PV600 to UPDATE on power up of the panelview?
I will try this code in the PLC with a "Piloted" Control List Selector...
Let me know if this is the right direction please...
Expanding on RBEYER
In PB32 go to
Application Settings > Terminal Setup --- Power up TAB
Then try changing the
Control Object Presets options box
Hit f1 and the help screen explains what each box does
Here is what I have now...
The problem is when I download to the PV, I have to manual change each page that has a Control List selector, the PLC has the correct values but the Control List Selectors do not update like all the other objects do...
I have the same issue as Daniel had in this old thread.
Every night the sanitation crew shuts down a palletizing area and when they power up, the PV1000 displays the default (initial state) control list items in my standard control list objects.
The items highlighted are not updated based on the contents of the PLC, so the operators may think the correct item is selected when it is not.
I don't want to write all tags to the controller on power up as this would generate a ton of other problems.
I don't need all the features of a piloted control list, I just want a standard one that won't LIE to me on power up everyday...
Looks like the fix is to switch to a piloted control list and use some PLC logic to manipulate the control tag and search tag.
If someone knows precisely how this should work it would sure help. Otherwise, I will experiment a little on my own and post my findings.
Thanks,
Paul
I have working code that I am looking at. (Didn't write it). It looks as if it is as simple as using the following to give what you want
Couple of extras
Make sure Product_Control = 0
Make sure that the State has Access set to "User and Controller"
PS the working code is doing other things that don't make it simple to read, extra features
How'd ya do?
Thanks MichaelG
That helped, but it still did not get the display in sync with the SLC following a power up. The stoopid panelview (I wish we used PanelMates here...) will show the lists in the initial state but it does not write to the write tag until the operator presses enter.
If I set the control bit, the panelview will update the piloted control list, but if I leave the bit set, it will not allow the operator to make a change...
So I had to add code to conditionally write to the control bits. The only thing I could come up with quickly was to use the page change register like this:
I have run into a situation where I am now on "borrowed time". Our company has finally used it's last PV600 "spare" and now we are going to have...
4,562
Hi all, I'm using an AB Logix5000 with a PV plus 600 compact. I'm trying to password a screen. I made a Numeric Input Enable button. I addressed...
1,179
Hello I would like to know if i did it well or what would be the easiest way if not: To connect my tag database from my RS500 project for a...
4,819
I'm a beginner to PLC and Hmi programming. any one please help how to connect HMI to pc. HMI has a printer **** enabled by default, It does not...
432
Hello, I've recently tried to upgrade my PLC controller from a L72 to L84ES and everything seemed to work, all buttons and screens as far...
2,643
