PVP 1000 gray screen
kurt.brinker
Dec 2006
In Town
263
We just got a panelview plus 1000 in and i created a new application with a few screens to test it out. I created a 4.0 runtime and downloaded it via ethernet to the panelview. It starts up like normal, shows that its running the application, i get the default alarm/info popup and i close that and then it just sits at a gray screen. I just setup a PVP 600 and used 4.0 and it worked fine. Whats the deal with this one?
btw: The intial screen is set to HOME.
set to home but did you actually designate a home screen???... when ya click the little running man does it run on the developement system ok?
Make sure in the User Account settings that the "DEFAULT" user has the correct Security Code to access the HOME screen.
via the Users Manual:
Assign the security code for the startup display to the DEFAULT user, or else the startup display won’t open. If the startup display uses the * security code, you can assign any code from A to P to open the display.
Edited: Just saw your note that you got everything up and running.
Hello, I made a small change to my FTV ME file (added an ack-all button) and re-downloaded to my PVP. Since then, when the application starts up...
1,056
Hi, im looking to migrate a 2711-K10C10 to a 2711P-T12W21 Panelview Plus 7 Standard. I migrate the PV1000 application .pba file in FactoryTalk...
2,015
Hi all Long time since ive asked for help hear but hear we go. I have been asked to make some new alarms on a lines panel view plus 1000 from a...
1,504
Hi ALL ! i have a .mer file of panel view plus 1000 (2711P) *screen resolution PVPlus700/1000. But i have panel view plus 1000 compact HMI...
1,398
I'm working on learning how configure Factorytalk applications to communicate through serial to older controllers but I've only got a beat up old...
2,729
