PWM and PTO
Ce.O
Sep 2018
MEXICO
19
Hello. Well, I need to use these instrucctions: PTO and PWM. I read the manual and I understood, I think so, but I have some doubts. I was reading about the bit enable status and said this:
The PTO EN (Enable Status) is controlled by the PTO sub-system. When
the rung preceding the PTO instruction is solved true, the PTO instruction
is enabled and the enable status bit is set. If the rung preceding the PTO
instruction transitions to a false state before the pulse sequence completes
its operation, the enable status bit resets (0). The EN bit operates as
follows:
• Set (1) - PTO is enabled
• Cleared (0) - PTO has completed, or the rung preceding the PTO is
false
So, the PWM is activated by the rung preceding, or by the rung where the pwm is?
You'll need to let us know which PLC, which software, and what versions you're using. The more detail, the better someone can help.
You're questions relate to setting EN and ENO which is a different topic from how PTO and PWM differ and best use for those technology objects (instructions).
*Generally* speaking and depending on you hardware and software PTO is used to control Servo and Stepper drives and PWM is used speed control and LED lighting etc.
Siemens has many,many examples for various applications which can get you started.
'rung preceding' generally means the instructions on the same rung leading up to the instruction in question. These instructions determine the True or False state which controls the operating of the instruction. So it's the same rung not the previously numbered rung.
Ok, I got it. I'm using Rs logix on PLC Allen Bradley.
I meant to say: So, the "PTO" is activated by the rung preceding, or by the rung where the "PTO" is?
Hi all, I have a Micrologix 1400 BWAA and the correct software for it. I would like to learn to program PWM to control a stepper. I am currently...
2,604
How will generated a 2 pulses outputs in the s7 1200 plc.... 2 pulse outputs of s7 1200 PTO or PWM are there.... i think PTO is digital output &...
7,032
Hello All, I'm new here so pls bear with me. :) I have an AB1500 PLC and I am trying to use the PWM or PTO function to control the speed of a...
3,300
Hi. I have a microLOGIX 1400, nice kit, cheap and you can get a cheap flavour of RSLogix (vis. micro) just for this controller. Anyway, I have...
4,977
hello , im using a s7 2xx plc i have a problem with the pto / pwm . i want to drive a steper motor every thing is ok , but the only problem...
4,938
