PWM motor control
Interesting circuit,
but to get to where you want to go, I would throw away this design and start from scratch. Although, you could keep everything to the right of the transistor 'Gate' and throw away the control circuit.
Doug
This is similar to another post I replied too. I assume you are going to control this with a plc? If so you could use an analog output instead of the potentiometer and use a timer to increment as wanted...ie if going from 0 to 12 in 3 seconds that would be 4 volts per sec which would mean 1 volt every .25 seconds which can be taken down to .4 volts every .01 seconds. I think my math is correct, I have the flu or something so not sure..looks ok.
This is just an example, the actual starting voltage and ramp specifications would be up to you...ie you may need to start at 6 volts and go to 12.
For that matter if the motor is small, current draw less than analog output ratings, then you may not need a controller at all.
There are a number of options, you could use multiple outputs with resistors to change the speed over time.
They make actuators, electric and pneumatic devices that can turn the pot.
I agree with Doug, may be better off going from scratch. Maybe use a digital potentiometer with a 555 ...the options are endless.
Hi friends... I have a problem about PWM (Pulse Width Modulation) in MRAS design to controlling dc motor. I have the algorithm to get control...
5,446
I need to drive a stepper motor with a PWM signal. I want to use a PLC to create the signal. Is there any documentation and/or sample code to...
5,662
Hello Guys, I have a project that I will be attempting for the first time, and need some help in implementing it. I have a 0.5HP Rotomag 110V...
12,670
I am new to plc's and am looking at using input from an encoder to sync the speed of a DC motor (0-90vdc .5 amps) the motor already has a variable...
6,960
Good morning! I'm trying to find a DIN rail-mountable 4-0channel PWM amplifier that is capable of accepting a 5VDC PWM with a maximum frequency...
118
