pzd ,pzw and akz
Amr Hassan
May 2005
340
i read a document on how to integrate a sipart closed loop controller to s7
it was written that i should assign the inputs to pdz ,the output to pdw
when i made my hardware configuration , only pdz and akz appeared , is akz equivlant to pzw
if i want to read/write a variable what should i use ? is it possible to write a PIw?
thanks
I have no idea what those abbreviations are for. If you have Simatic S7 fully installed you should be able to goto SIMATIC then S7 Manuals and see PID control (English and Deutsch), the pdf is S7PIDCOB.pdf. There is also a manual for parameter assignments.
Hi, I'm using PPO1 to communicate with MM440. I only need to read and modify MM440 parameters, so i sucssesfully use PKW mechanism. I don't have...
1,307
Dear All, Could anyone help me for driving simoreg 6RA70 series though profibus with PPO5, 4PKW,10PZD?
2,736
