MM440+Profibus. Dont need to use PZD in PPO1!
Nov 2013
milky way
I'm using PPO1 to communicate with MM440. I only need to read and modify MM440 parameters, so i sucssesfully use PKW mechanism. I don't have to start/stop MM440 by means of profibus, so i don't use PZD at the moment. Frequency is adjusted by potentiometer. Everything works great, but the only problem is that LED indicator on my Profibus CB is flashing green: Cyclical process data exchange in progress, but setpoints invalid (control
word = 0)
. But, as i've said, in my case, i don't want to send any setpoints/control words to MM. Or, maybe, i'm supposed to send some kind of special control word that just executes "nothing"?
So, how could i make led be just green without flashing? If there was a telegram format without any PZD, i would definetily use it instead of PPO1...
Hi; First of all, I am sorry that my post is not relevant with this forum. I have recently purchased Samsung cell phone. I have alreay saved...
79
Hi I am in the process of making an OT lab for training and to test incident response, an i keep hearing NOT to scan network because some...
902
A MELSOFT application error has occurred. Please restart. <ES:020000006> Why Occur this message? I'm try connecting to USB Pls Help me..:shock:
2,042
I have a Delta DVP 16EC PLC and does not have a RUN-STOP button I can make it go into RUN with the PC in the simulation and everything is perfect...
2,015
Hello, I'm running my Plc in PLC Simulator (Unity Pro XL). Intouch sees the connected links but the tags are not matching (+1 on InTouch)...
1,253
