Q: About Carlo Gavazzi Dupline
amkleist
Oct 2012
EU
I'm working on a PLC project including Duplines from Carlo Gavazzi, the specifik model-number are: Type G 3496 0003
I'm working on two different kind og Mitsubishi PLCs.
I do have some difficults understanden the result of the Dip-Switch Setting. There are 6 switches on the Dupline Master Module, but only 4 switches are describes in the datasheet?
Then I don't really understand the consequences of the settings. Can any please help me out here?
Dip-Switch Setting
Sw.2
On: If Communication fails, all Dupline®
channels activated by the PLC, is activated.
Off: If Communication fails, all Dupline®
channels activated by the PLC, remains activated.
Sw.3
On: Programming-port Protocol (Power up the
Module)
Off: Dedicated Protocol 1 (Power up the
Module)
Sw.4
On: Split I/O Channel Generator Mode (See “Mode of Operation”)
Off: Normal Dupline® Monostable Channel
Generator Mode
Sw.5
On: 64 Dupline® channels
Off: 128 Dupline® channels
If I have 5 Dupline Slaves connected to the Dupline Master, how does each slave know what adress it has (adress A-E)? What would happen if an error occur on Slave number 3?
Best regards
Hello! I have made connection in TIA portal with an energy analyzer(Carlo Gavazzi EM26-96) using Modbus RTU. What I am mainly looking for is...
798
Hello, We're trying to connect to carlo gavazzi wm14-96 using tia portal. But we couldn't find any gsd file for it. Could you please help? Thanks
1,131
Hi, I just need some help. i've been trying to communicate a power meter to rslogix5000. carlo gavazzi wm40-96 with comm module MC EI ETHERNET/IP...
2,976
Hi guys. I have a power meter (Carlo Gavazzi WM14-96) communicated to the PLC (AB CompactLogix L35E) via profibus. I have gotten the values, but I...
3,401
Hi all, I have a machine with a PLC ELC2001 from Carlo Gavazzi wich is stopped and I need to chech the program but I don't have neither the...
2,702
