Q. on Modbus w/ Phoenix Contact ILC PLC
FNC
May 2010
NJ
84
I am using Phoenix Contact ILC 191 PLC for the first time. It has a built-in Modbus Server which works well for integers but I cannot get it to work for floating points.
I want to change a float into 2 consecutive registers which can then read easily by any Modbus client.
Has anyone ever done this with Phoenix Contact PLCs?
Thanks.
FC
Converting Real to INT
My problem is that I cannot figure out how to convert 12.3 into two integers.
When I try to convert 12.3 into DINT or DWORD I end up with 12.
With Rockwell there was the CPW command which did this exaclty. I am not sure if Phoenix Contact PLCs can do the same thing.
I am using PC Worx for the first time.
I have tried REAL_TO_DINT and REAL_TO_DWORD. Neither gives me what I need.
Is there some other function block that I can use?
all the real_to functions will round to a whole number.
I am wondering what happens if you dump your REAL value into your register and set that register as DWORD datatype or a WORD with a length of 2 if that will solve it, it should push it out as a binary number
01000001010001001100110011001101
I haven't used pcworx much so just shooting in the dark trying to help
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
231
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
170
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
