Q. on Modbus w/ Phoenix Contact ILC PLC
FNC
May 2010
NJ
84
I am using Phoenix Contact ILC 191 PLC for the first time. It has a built-in Modbus Server which works well for integers but I cannot get it to work for floating points.
I want to change a float into 2 consecutive registers which can then read easily by any Modbus client.
Has anyone ever done this with Phoenix Contact PLCs?
Thanks.
FC
Converting Real to INT
My problem is that I cannot figure out how to convert 12.3 into two integers.
When I try to convert 12.3 into DINT or DWORD I end up with 12.
With Rockwell there was the CPW command which did this exaclty. I am not sure if Phoenix Contact PLCs can do the same thing.
I am using PC Worx for the first time.
I have tried REAL_TO_DINT and REAL_TO_DWORD. Neither gives me what I need.
Is there some other function block that I can use?
all the real_to functions will round to a whole number.
I am wondering what happens if you dump your REAL value into your register and set that register as DWORD datatype or a WORD with a length of 2 if that will solve it, it should push it out as a binary number
01000001010001001100110011001101
I haven't used pcworx much so just shooting in the dark trying to help
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
131
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
88
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
361
138
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
304
