Coops Member C Join Date Dec 2004 Posts 103 Oct 18, 2012 #1 Hi, I have a Q series PLC (Q06UDEH) and I'm using GX IEC Developer. On compiling I'm getting the error message: F1034 More bit addresses needed than defined in system variables. Any ideas on how to correct this error? Cheers
iant Lifetime Supporting Member + Moderator Join Date May 2002 Location Melbourne Posts 3,691 Oct 18, 2012 #2 I dont use GX IEX It sounds that your Aray or Variable is determined incorrectly
Chris Taylor Lifetime Supporting Member Join Date Feb 2011 Location Canterbury Posts 257 Oct 18, 2012 #3 Coops with your project loaded go to Extras in the tool bar Select Options The go to the bottom and select Project Options and then System Variables. You can modify your ranges Chris
