QJ71E71-100 to Host System using GX IEC Developer
mkko
Oct 2011
Pune
Can Anybody please help me with the settings required to cofigure a Mitsubishi QJ71E71-100 Ethernet Module to communicate with a host System . I have directly connected the Ethernet module to the Host System using a cross cable.I have Gx IEC Developer available.
If any one can contribute a sample project , it would be really great .
Thanks in Advance .
You need to set up the cards in GX, off hand I'm not in the office at the moment but I will get you a sample project however what are you communicating with as that will determine what protocol you use i.e. TCP or UDP, is this for Melsec communications or some other type of software etc.
I can give you some idea in the form of a project & the steps to follow.
If this is for GX developer then use MESEC connection in the setup.
Below is one for melsec communication this will work even with UDP connections as proved with Kepserver there is no ladder program needed for melsec or Kepserver opc communications
hi all regarding : mitsi q series ethernet qj71e71-100. there's an old coax network at a client's chicken factory that's fallen over. it...
1,929
Is anyone familiar with C013 errors on Mitsubishi QJ71E71-100 Ethernet module? C013: The port number used in a connection already opened is set...
1,691
Hello all. My name is Robert Siegfred. My company is TDS Automation L.L.C. I have recently been upgrading A-Series PLC to Q-Series and have been...
2,340
I Have Problem With Send Data From Station To Station In Same Network In "JP.ZNWR" Command But No Problem With Send Data All Station In Same...
3,949
Hi all, I have problem communicating with Mitsubishi QJ71E71-100 Modul to PC. Does anybody know how to set the parameter in GX Developer 8.65...
4,065
