Quality of the ADAM I/O?
CCZ
Mar 2009
FL
25
Hi Everyone,
Longtime lurker here - Thanks for all the help you have offered in the past.
What is your opinion on the quality and robustness of the Advantech ADAM I/O modules? Specifically I am looking at the ADAM-4055.
I am sort-of stuck with Modbus comms and I am going to have a few outputs (~20)spread over a large (~4 acre) area. Running wire back to the controller is always an option.
Of course I want it to be bulletproof and free :)
Thanks,
Chris
We have been using the 4050 and 4017 in the industry for the last 10 years with no problems.
I highly recommend adam IO units. I cant recall one ever failing and we have used probably a hundred or more over the years.
Hi. I'm wondering which road to go. Let say I have a bunch of analog values I need to display. Let's call them RTD1, RTD2, etc. for the example...
1,080
I have a plant-wide project pulling data from numerous PLCs (20-30 PLCs) into a redundant Kepware Server. We are talking 2000+ tags. I'm hearing...
1,530
I just received the Panelview plus 7 performance series B. When I put my .mer file on the series B, the text quality is way worse than the series...
2,405
Hi guys, A new client has an existing system that works just fine (surface water plant) but they had a falling out with the previous integrator...
18
4,511
Ok, this probably is not a new issue but it id doing my Head in.. Firstly, GE this is the single most worst PLC platform I have used in 22 years...
2,906
