Query regarding common positive and common negative in a stepper driver
arbj
May 2011
mrt
61
I am connecting an Autonics make stepper driver type, MD5-ND14 to a Kinco PLC (K205 series) this has a sourcing output which cannot be changed to sinking.
I have tried out two different types of connections, common positive & common negative. The circuits are attached. Only the common negative works.
Could anyone explain why? I would prefer the common positive option. Any way this can be realized?
Link to MD5-ND14 datasheet
https://www.dropbox.com/s/6yvh4z2hsvnaedy/MD5-ND14.pdf?dl=0
Link to Kinco K2 datasheet
https://www.dropbox.com/s/381eokibm3ku39l/L011558 - Kinco K205E PLC Spec Sheet.pdf?dl=0
a
As you pointed out, the K205 PLC has outputs that are sourcing only (common negative). Technically you might be able to drive one of the stepper signals by connecting the PLC negative to the stepper input, and the PLC output to IL+. In effect this would drive the entire 24v+ bus from a single PLC output, so you couldn't do both CW and CCW rotation.
If you want to have common positive to the stepper drive without changing the PLC, I think your best option would be to add a solid state relay in between. You would have to make sure that the switching rate of the relay is sufficient.
Thanks....
i want my utility room fully automatic. once i fed the schedule it is being carried all over the month. please suggest any control system.i have...
4,443
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
158
Hi, we are using allen bradley plc. for loading the data from plc to buffer i am using FFL/ FFU. and loading the data in buffer array. it worked...
354
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,274
I came across this online test question about tags - has anyone taken a Siemens course and know what is meant by "scope"?
1,446
