Question about Activity Log of RS View32 works
AB2005
Nov 2006
Lahore
320
Hi;
In RS View32 works, I want that if for example; the sum of Numeric input A + B + C is greater/less than the value of Numeric input D, an error message should appear in Activity Log bar. Is it possible? If not then please guide to the other way to create and display an error message in run time.
Probably the easiest way is to create a Derived Tag (Edit Mode: "Logic and Control, Derived Tags"), with an expression that is true when your oonditions are met. Then in your Tag Editor, you should set up the new ALARM_10 Tag to be displayed however you desire with whatever message you want in your Alarm Banner.
I recently uploaded an aplication from a Panel View, created a new screen and now that I've downloaded it to the Panel View, all the texts have...
154
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
135
Hi All, So I have a main routine with an instruction that's executed by XIC "Run" I have a JSR located on a rung below it. In the logic for that...
240
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
103
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
200
