Question about Activity Log of RS View32 works
AB2005
Nov 2006
Lahore
318
Hi;
In RS View32 works, I want that if for example; the sum of Numeric input A + B + C is greater/less than the value of Numeric input D, an error message should appear in Activity Log bar. Is it possible? If not then please guide to the other way to create and display an error message in run time.
Probably the easiest way is to create a Derived Tag (Edit Mode: "Logic and Control, Derived Tags"), with an expression that is true when your oonditions are met. Then in your Tag Editor, you should set up the new ALARM_10 Tag to be displayed however you desire with whatever message you want in your Alarm Banner.
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
173
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
73
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
97
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
