Question about Digital Output Card(1756-OA16)
spm_cpl
Jan 2009
Taipei
Hi~
This is 1756-OA16 simply schematic.
And I have two questions.
Hope you can explain for me by this diagram. Thanks!!
Q1:when no output command, and no Load, why we can measure the 110VAC from OUT-0 (relative the ground)?? I mean, no output command,why it has voltage 110VAC. And, when it has Load, we have no l10VAC at OUT-0. So....I confuse it....:((is it a virtual voltage?? or something??) when we try to give it output command, everything is normal.
Q2:when take off the fuse testing.And no Load , no output command ,we still have ll0VAC at OUT-0 ?? why?? we have taken off the fuse!! And when we give output command, it has no 110VAC because no fuse, it's right.
Thanks your answer. Thank you very much.:)
Sorry my English, if you can't understand what I mean.:)
See Picture below, note leakage current spec. All solid state devices leak a little. There is always a little current flowing (even when off) so you are going to see voltage.
Greetings spm_cpl ...
my distinguished colleague Mickey has already given you the answer to your question ... if you'd like to read more about the issue, the thread below should be helpful ...
http://www.plctalk.net/qanda/showthread.php?postid=12891#post12891
I particularly recommend that you at least read the "scary story" part in the post that I linked ... there can be serious safety issues associated with the "leakage current" effect ...
and your English is completely understandable ...
welcome to the forum ...
hi, I need to select digital input modules for a Controllogix PLC system for an industrial application. The inputs are various selector...
2,116
Hi, I have a question to implement digital logic. these are.....I have total 8 inputs and my question is any 2 of 8 inputs is true, the output...
2,158
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
169
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
73
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
