Question about gear reduction ratio
amir81
Aug 2005
Hi all,
I have some questions about gear-motors and I hope you can help me to find their answers. We use some of Bauer gear-motor products in our factory for many years. Recently we need to change the application of a BG80/D13MA4 to hoist application, driven by an inverter.
On the nameplate of the motor, the following data are written:
P=7.5 kW
n2=65 rpm
n1=1420 rpm
I=15.8 A
PF=0.85
f=50 Hz
According to above data the gear ratio should be approximately 21.85. But in Bauer-CAT software, when I chose the above gear-motor (attached file "1.jpg") and click on the next screen button, it showed me a table with 13 rows of configuration (attached file "2.jpg"). Strangely, the gear ratio of SAME gear is changing, from 26 to 63. As far as I know, the gear ratio of the gear is always constant!!
Next, I changed the electrical supply combo-box to "mains duty" (attached file "3.jpg") and click on next screen button. The new table of configuration has 10 rows and in the P2 column, the value of 9.5 kW is written (attached file "4.jpg"). The hoist application is not S1 (continuous) type and in fact it is S3/S6 one.
The abovementioned scenario raised following questions in my mind that I want you to help me to find their answers, please:
1. Why there is numerous "gear ratio" for a single gear?
2. Why there is 5.5 kW configuration, even when I chose 7.5 kW motor type?
3. Which of reported torques is correct to assume for the hoist application?
4. We want to use a 7.5 kW inverter to drive the gear-motor of the hoist (the stated power rating on the motor nameplate). Should we use a 9.5 kW instead, if the data of the software was correct?
Thank you.
It looks like your selection of 'BG80' for the gear type is a generalized helical gear housing which can have many different ratios not specified by just 'BG80' - thus various torque outputs and speeds are listed depending on the exact gearing.
Hi
I think you are right. This can only describe why there is different reduction ratio.
But what about required power? Which of 7.5 or 9.5 is correct for hoist? and do I need to change the inverter to achieve more output power?
thanks
thanks
Power required is determined by the load. You indicated this is a hoist:
hp = (F x S) / (33000 x eff)
F = force exerted by the load, pounds
S = speed of lift, feet per minute
33,000 ft lb per minute = 1 hp by definition
eff = decimal efficiency of the gear reducer and motor combined
You may need to oversize the drive because this is a constant torque load, potentially requiring full current output from the drive across the speed range. Check with your drive supplier.
I have a virtual master that drives all servos. How do I make Virtual Master or any Servo to follow regular encoder which is driven by Regular...
3,182
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
89
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
197
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
195
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
108
