Question about operator station in Omron system
timcph2008
Jul 2015
United State
33
Hello guys,
I have a question about operator stations in omron system.
From the manual I read, the basic system setup is using omron NS Series PT for the HMI. CX-designer can easily transfer project and graphics to NS Series PTs and the PT can communicate with PLC via different protocol.
Here is my question:
Is it possible using a computer, with windows OS, as an operation station? I am using omron CS1G as controller, I believe I can use an ethernet unit(CS1W-ETN11) for the PLC and operation station communication. However, I am not sure CX-one would have any function for operation station like a wonderware. Seems the NS hardware is a must.
Thank you for you guys help! Please let me know if you have any question.
I just found a piece of code using an operator "+=" IF tag1 AND tag2 THEN tag3 += tag4; tag5 := tag5 + tag6; END_IF; I don't...
4,921
I recently uploaded an aplication from a Panel View, created a new screen and now that I've downloaded it to the Panel View, all the texts have...
155
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
139
Hi All, So I have a main routine with an instruction that's executed by XIC "Run" I have a JSR located on a rung below it. In the logic for that...
244
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
104
