Question about Stepping motor
Makinen
Guest
M
When i drive up a stepping motor at lower speed, the vibration is excited than high speed...
Is it a normal condition?
if not, shall i increase the pulse rate from PLC to reduce the vibration?
Yes, it is normal condition.
Try to find,if your stepper motor controller support "Microsteping" and use more microsteps to one full step at lower speeds.
Some controllers supports the possibility to change waveform shaping,too.(For instance sinewave,trapezoid,triangle etc) Try to change it.It may helps.
stepper resonance
Apparently your stepper has entered into a resonance which is not uncommon.
Resonance is an unstable condition when running a step motor. Resonance usually occurs between 2-4 rev/sec and can be alleviated in most situations by putting a load on the motor, changing from full stepping to half or microstepping, or increasing your acceleration through the resonance zone.
Main problem is the loss of torque while in the resonance zone.
This weekend a friend of mine at a plant I used to service called me. (note: I serviced his plant when I worked for my 'former employer'). My...
3,616
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
63
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
184
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
166
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
102
