Question for Ethernet on ML1000 (Ken Roach?)
504bloke
Jan 2005
Down South
2,721
Hi
Just thought id ask a quick question before i spend a morning playing to find i cant do it!
Basiically can i connect to an ML 1000 for programming purposes via the following
My PC on Broadband > Remote control via www.LOGMEIN.com > Remote PC on Broadband with Logix 500 & RSLinx installed (this PC is on wireless ethernet) > Wireless accesspoint hardwired to NET-ENI > NET ENI wired to ML1000
I have done it on DH+ on SLC's but never ML's on ethernet ?
I think i can but before i waste a load of time i thought id ask!
That should work just fine if you have the access point and NET-ENI setup correctly. I would recommend starting with just the NET-ENI to the ML1000 to the desktop first. Then keep incrementing through instead of trying to test it all at once.
Yes, such a system should work fine.
I have set up and used such systems with PLC-5E, SLC-5/05, ControlLogix 1756-ENBT and 1761-NET-ENI's and the handful of wireless routers I have access to: Netgear MR314, Linksys WET11G, and Linksys WRT54G.
Good advice above; set the system up first with the local PC, AP, and Net-ENI and the remote login system should have no effect.
One question; is Internet broadband connection connected directly to the laptop, or is it connected to the wireless Access Point ? Whenever there is security and firewalling on Ethernet, you have to hedge your answers a little bit.
(Sorry I didn't answer a thread with my name on it; I've been on a round-the-clock project since 9/30)
Hello, I have a ControlLogix L73 at firmware 24.11, Logix Designer at version 24 I have a 1734-AENT Point IO ethernet adapter, the box says...
1,650
Consider two control panels 100 meters apart. Customer is to run fiber between them so the PLC can talk to the HMI. Each panel has an A/B...
29
8,748
Hi guys I hope your all safe and well , I have a question regarding a slc 505 on ethernet is it possible to add a ethernet remote I/O module...
1,880
I am replacing a powerflex 525 on ethernet/ip with a stratix switch. I am upping the drive from a 2 to 3HP. All i should have to change is drive...
1,131
This may be a simple question. I understand the concept and application of analog modules (i.e. Compactlogix) for transducers, and outputs for VFD...
2,110
