question on Kepware.
briana banks
Jul 2005
242
Hi All
Using Kepware OPC Server modbus ethernet driver.
If I have a WORD size tag in the controller
and i want to use a single bit it . e.g. TAG.0 in it
how do i reference it in Kepware server when i create tags in it.
Thank you.
You mean you want to adress a bit in a register ?
If you click the ? button next to the tag adress field in KEPServer, you get a listing of possible adressing formats.
Note that this only works if the controller supports mask write register (Function code 22)!!
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
60
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
184
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
160
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
102
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
112
