Question
A Google cache search with baumer tw tb
http://www.baumerelectric.com/be40.html?L=1
Nominal sensing distance Tw
The nominal sensing distance, Tw, is the maximum sensing distance of the sensor, measured at +25б╟ centigrade, using a white card (Kodak card number 1,527,795, size 200 x 200 mm). At distances below 400 mm, the object size is 100 x 100 mm. The excess gain (factor 1,5) under ideal ******t conditions is included in this value. Sensors with the alignment aid show this point with a constant (not flashing) LED.
Actual sensing range Tb
The actual sensing range Tb is between the adjusted nominal sensing distance Tw and the blind region. The blind region is the area immediately before the lens, in which target recognition cannot be guaranteed. Within the actual sensing range, a standard Kodak white target will always be detected.
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
87
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
196
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
190
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
107
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
114
