Lionel,
I reviewed your program. On Rung 000, the "RUN/OFF SWITCH" I:1/2 is not a true safety condition as are the other inputs on the rung, with an output called "SAFETY CONDITIONS MET". I suggest moving I:1/2 to Rung 005. oN rUNGS 005, 009, 012, what happens if there is a power loss, evebydoy takes the rest of the day off and goes home, then the power is restored. All your belts will restart! Rung 005 should be probably be set up something like this, with a seal-in contact to drop out the motor upon power loss:
