Queuing in ladder logic using only the 4 basic operators
You would also need the development software and maybe the simulator and almost certainly the compiler for the PLC.
Another alternative would be to get an Automation Direct PLC and use it to do the 'queuing' using digital I/O if needed to inform the MicrLok PLC of the box's status when it gets to the diverting portion of the system.
to add a new bit to the "buffer":
Code:
 C    Add   D
 D    Add |
C->D
B->C
A->B
New->A
to remove one from the buffer, you would need to track how long the buffer is, and pull that data out. You might need, essentially, a parallel buffer that only has one bit true, to track which element of the FIFO buffer is the one to read out of. You'd need to write the read command for all the possible elements, and only one would execute, then you'd have bump the parallel buffer down one.
In practice, this would grow super tedious very quickly if you need a FIFO buffer bigger than 3 or 4 layers deep.
Thanks for the ideas. I am only using a buffer that's 3 or 4 layers. What I'm a little confused on us do I need two buffers for the two boxes of just one?
Also, I guess I can use a micrologix unit and do the fifo there, will require some wiring and hardware changes so I would like to avoid but if necessary I will look into
If you really can't upgrade it (and serial comms are trivial to implement nowadays to be honest), can you possibly just add a new PLC to handle your advanced logic and send outputs to the old, slow, non-configurable thing you have?
Does any one know how to realize MSMQ queuing sending/receive from PLC to PC?
1,156
Hi Friends While I try to install PCS7 .I must Install WINCC so I should have Message Queuing but By this Alarm "The properties of this computer...
2,308
I have been struggling to transmit multiple messages to a serial printer with S7-200. I seem to have overcome this with the attached program, but...
3,006
Dear All I have got 3 water treatment plant (RO) and they require backwash. each RO send to my PLC one DI signal to tell me that it needs...
1,859
I got my PanelView Plus 7 working with a Micrologix 1500. How would I connect my laptop to the PanelView to view the ladder logic while operating...
152
