Quick Help
ttl ic Transistor Transistor logic
usually 5V dc input
used for Fast inputs
BCD is binary coded decimal.
it is unrelated to the type of input card.
but it is a form of data that consists of atleast 4 inputs
you write the code to determine haw you use it
thanks for you iant
for TTL is it different form special modules that use for fast input
about BCD modules have you any simple example to make it clear for me
look for TTL a databook from texas instrumnets.
old technique to have digital control with AND OR NAND etc.
the 7400 series was famous for this
BCD is a code for display.
the byte is divided into nibble and each nibble is for one hewdisplay.
look in wiki
So the quick and short of the situation is that I designed an axle press that was sent to one of my company's other facilities. That facility just...
19
4,262
Q(1) Design a controlling system using DVP-40ES Delta PLC for a threestory Elevator Prototype as shown in the figure below. Show in details the...
2,171
Could somebody please help me with this quick question? The input range from an analogue sensor is unsuitable. What would you do, from a safety...
17
3,096
Hello, I am trying to illuminate an indicator on my G310 HMI using Complex Code in the control status portion of the illuminator I chose. I am...
1,386
Hi, I am working on Proficy Machine Edition 5.9. I want to download the HMI to Quick panel (IC754VSL12CTD). Can anybody help me on the procedure...
3,266
