radio modem
kelly
May 2003
Saskatoon, Saskatchewan
i can't remember how to do ladder logic for simple transfer of data on a modem. I am receiving a 4-20mA signal into a Modicon Momentum plc with a analog module 170 AMM 090 which accepts 4-20mA directly. So all I need to do is accept the analog signal on a 3XXXX register then transfer it to a 4XXXX holding register. Also I was asked to give a status of both the plc and modem to be sent to receiver. Now some how my modem has to send this info.
Brain ****!!! :oops:
If your modem is always live and connected to the PLC, it is treated by the PLC just like a hardwired serial connection. Use the same read/write commands you would use for direct serial connection. If your radio modem has a key function, use an output on the PLC to turn on the modem transmit a fraction of a second before you enable the write.
A Modicon 984 Ladder Logic command for transferring data from one register to another is BLKM (block move)
Please any body help me how to connect a DATALINK radio modem SRM6330 to Allen Bradley Controller 1756-L71 using Ethernet link between the two? Thanks
1,670
We have an upcoming project which specs call for a L32E. The customer recently had a failure on a phone line controlling their raw water pumps so...
2,588
I have 4 digital IO signals on a remote shuttle I need to radio modem back to 4 Digital Input Points on a 1771-IA16 I am looking for a Radio...
2,641
Hi All. The site has got an existing radio RM9600E-460 radio modem. It has a RS232 and RS485 port. But what is the protocol ? Now I wanted to...
2,218
I'm looking for app help where the spec requires a remotely mounted disolved Ozone instrumnet that transmits its value over radio. I have the...
2,919
